It is currently Sat May 18, 2013 8:00 am
Post new topic Reply to topic  [ 3 posts ]
 Post subject: JJSPEC Racing Custom Fuel Cell
PostPosted: Mon Dec 20, 2010 9:39 pm
We will be offering a custom fuel cell that will fit in a 92-2000 Civic and 94 -2001 Integra and fit in the original location of the factory fuel tank and use the factory fill pipe. Capacity is 5 gallons but if it needs to hold more that is not a problem as they will be made to order. The 5 gallon unit weighs about 5 lbs which is 20+ lbs lighter than a factory unit. I will post up the pictures of the straps and mounting hardware tomorrow.
The sump with a single -12(any combination of AN or pipe thread can be used, just specify at time of order):
A pic of the top before the sump welded is on:
Bottom pic:
Other custom options such as in-tank fuel pump(s) mounting options, fuel level sending units, etc are available as per customer request. If you would like something like this for a non Honda product we would just need your vehicle so we can fabricate one to fit your needs.
JJSPEC Racing 765 Gray Hwy Macon, Ga
478 621 5000
 Post subject: Re: JJSPEC Racing Custom Fuel Cell
PostPosted: Thu Dec 23, 2010 10:57 pm
not bad use factory straps?
www.mainstreamperformance.com
MAINSTREAM PERFORMANCE
PostPosted: Fri Dec 24, 2010 12:05 am
Thanks. Could probably be made to work, but the ones we made were actually in a "Z" shape to hold the cell firmly in place. They are a little different than others I have seen, but from some of the testing from some of the other cells I built, I felt they were necessary as the factory straps were more giving. I will post up picks when I get a chance since tonight is the first night this week that I left the shop before 9pm and I had to get some Christmas gifts for the wife or it might not have been pretty Christmas morning, haha!
478 621 5000
