It is currently Tue May 21, 2013 4:18 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: if you had...
PostPosted: Sun Oct 31, 2010 7:49 pm
^^ i like the way u think lol
PostPosted: Sun Oct 31, 2010 9:22 pm
Gotta be nice to your kids......for they pick your nursing home. :D
PostPosted: Sun Oct 31, 2010 11:09 pm
I would lock the 10 grand in the trunk and use my car a mobile ATM for just me.
PostPosted: Sun Oct 31, 2010 11:47 pm
for me
precision 76mm turbo $2000
edelbrock carb lower with injector bosses drilled $300
edelbrock upper intake tube $115
90mm throttle body $250
tko700 trans $2000
Boss 302 block $1500
SCAT forged rotating assembly $1800
2 Bullit 17x10.5 rims $300 (already have the front ones)
Strange QA-1 front suspension kit $1200
New rear control arms $500
Total: $9965
PostPosted: Mon Nov 01, 2010 2:31 am
^^ i guess that extra 34 bucks would be gaskets?? haha
PostPosted: Mon Nov 01, 2010 2:46 am
MMR Mod 2500 5.4 aluminum shortblock--$9300
:confused:
lol seriously though......
Forged 5.4 shortblock--$4000
Send my heads to be PP and 1mm oversized valves--$1500
Custom grind cams--$1200
Comp Cams beehive valve springs--$400
Aussie Boss 290 intake manifold--$2500
I already have a built 4R70W sitting here so--freebie
Total $9600 leaving $400 to fix the stock converter that will fail taking out my built trans with it and rear end from the new power........... and the blown motor from not having enough money to buy a new fuel system lol
The realistic build that would let me buy everything to keep it together........
8.8 with welded axles tubes, 31 spline axles, 03 cobra 31 spline diff., and 4.10's----~$1000
Built trans I already own---Free
4500 stall converter---~$1000
Send my heads to be PP---$1000
Custom grind cams with Comp beehive springs---$1600
Fuel system---$1000
298" stroker rotating assembly using my stock block--$2400
Ported short runner intake manifold---$700
Tuning---$400
Metco Upper and lower control arms---~500
Strange shocks and struts---$400
Total price 10,000
Still needs wheels, tires, coil-over kit, and a few other miscellaneous things that are not power related.
I actually had a really hard time staying under 10k lol. I kept having to tone down the build :?
PostPosted: Mon Nov 01, 2010 4:21 am
My reality answer:
finish up jdm front and paint - 1500
wheels/tires - 1200
Intake - 200
TB - 150ish
mani - 250
cams - 350
header - 350
exhaust - 250
tune - 300
suspension - 1500
$6050
PostPosted: Mon Nov 01, 2010 1:38 pm
:confused:
Fuel system---$1000
Tuning---$400
Total price 10,000
You know why you had a hard time??? Cause you has a modular ford :tongue: them bitches are to expensive
PostPosted: Mon Nov 01, 2010 2:12 pm
I always have to do it the difficult way. I have to be stupid and want to build an n/a modular. Why couldn't I just get some forged pistons and rods then throw on an eaton swap or a used procharger kit for $3k :(
Oh well at least it runs 10's the way it sits right now :D
PostPosted: Mon Nov 01, 2010 3:25 pm
N/A modular ftl and you should went boost the procharged mach1's are teh sex, and damn straight mustangs run 10's
PostPosted: Mon Nov 01, 2010 7:53 pm
damn. sounds like alot of cars in here would be slow :P
PostPosted: Tue Nov 02, 2010 1:54 am
Especially the OP's car :ninja: :D
PostPosted: Tue Nov 02, 2010 3:00 am
oh yea. it would be slower the a d series running on one piston haha
PostPosted: Tue Nov 02, 2010 9:05 pm
Mine would damn sure be slow. My son doesn't need anything fast yet.
PostPosted: Wed Nov 03, 2010 8:45 pm
no one else doesnt have any 10grand dreams???
haha
