It is currently Wed Jun 19, 2013 12:12 pm
Post new topic Reply to topic  [ 13 posts ]
 Post subject: emissions & tag dilemma...
PostPosted: Sat Dec 25, 2010 10:22 pm
Hokay,
We all know that in order to get a tag, you need to pass emissions... and in order to pass emissions you need to drive the car on the street, which is kind of hard without a tag (legally, anyways)
Here's my dilemma... I have a brand new obd2 motor, that hasn't even been heat cycled that I want to get street legal. It currently has expired tags, and it missed emissions this past October cause it was down for repairs...
I'm not sure if an engine that hasn't been fully broken in will pass emissions. Isn't there a certain drive cycle that it has to go through before the readiness monitors are able to be tested? Car has all its cats, EGR, and pretty much every single emissions related part still in tact.
Whats the best way to go about getting the car street legal?
Thanks :banana: :banana: :banana:
come at me, bro.
 Post subject: Re: emissions & tag dilemma...
PostPosted: Sat Dec 25, 2010 11:59 pm
Far as I know, a new engine shouldn't have any issues passing emissions, especially if it's built to stock specs (which I'm guessing it is since it hasn't been run, i.e. no tuning).. There's really only one way to find out if it'll pass or fail, though, which is to go get it tested.
Also, as far as I know, if you get pulled over on the way there, you should be fine with telling them you're driving to do emissions and then directly back home. Technically, you could tow it, but.....
PostPosted: Sun Dec 26, 2010 12:45 am
i was just always under the impression that every car had a readiness state that it has to reach. i think it may be called a drive cycle or something, which lets the ECU check out all the emissions things on the cars in various driving conditions.
i could be wrong though
come at me, bro.
PostPosted: Sun Dec 26, 2010 9:03 am
Just drive the car ofr a few minutes prior to going to the emissions station. It is highly unlikely that you will get pulled over, but if you do, tell the officer the truth that you are going to emissions.
If he wants to give you a ticket, which is unlikely but possible, just take the ticket and go on with yout driving and emissions testing. In that scenario, you take the emissions sheet to the judge with the ticket - no matter if is passes or fails. This shows that you were within the law.
PostPosted: Sun Dec 26, 2010 9:58 am
I think I can procure a dealer tag for the right price....
PostPosted: Mon Dec 27, 2010 7:15 pm
what kinda motor and car is this?
PostPosted: Wed Dec 29, 2010 12:47 am
JAMES YGPM.
come at me, bro.
PostPosted: Wed Dec 29, 2010 11:10 am
As far as i know a fresh computer starts out with all codes good. So assuming everything is good once the motor starts up no codes will be triggered and you should be good to go.
If you start it up and get a check engine, don't waste your time going to emissions, you'll have to fix the code issue first. Or just move out to this area where you don't have to worry about that junk.
Long story short there is no drive/cycle time, by the time you get out of the neighboorhood the computer will have flashed a code if there is an issue.
PostPosted: Wed Dec 29, 2010 11:23 am
ill give you a dealer drive out tag from my dads car lot. it will help you from getting pulled over....once you do get pulled over and you dont have proof you just bought the car then your on your own from there though lol
PHOTOGRAPHER FOR: CANIBEAT.COM | HONDA TUNING | MODIFIED MAGAZINE | 5.0 MUSTANGS & SUPER FORDS
2003 PONTIAC VIBE GT. I DRIVE A VIBERATOR. DONT JUDGE ME.
FREE PHOTOSHOOT GIVEAWAY ONCE I GET 1000 FACOBOOK FANS
PostPosted: Wed Dec 29, 2010 10:32 pm
Eric, you're right. Every car has to be driven a minimum of 50-75 miles to cycle through it's readiness tests. Every car varies so your's could be less or it could be more. Drive 50 miles, have it tested and you'll find out. Anytime the CEL has been erased, the car has to be driven. We have an application which will put it through it's readiness test in as little as ~30 minutes but it wouldn't be worth your drive. I deal with this on a daily basis so I know what I'm talking about.
If you do get pulled over, as long as your courteous and explain what your's doing, they should let you off with a warning even driving with an expired tag. You'd be more likely to get pulled over without a tag than with an expired tag.
PostPosted: Thu Dec 30, 2010 10:21 am
You can always have a friend or relative follow behind you to the testing as well.
Hell, just call in a police escort.... lol
PostPosted: Tue Dec 06, 2011 7:39 pm
If he wants to provide you a solution, which is unlikely but possible, just take the solution and go on with yout generating and pollutants examining. In that situation, you take the pollutants piece to the assess with the solution - no issue if is moves or neglects. This demonstrates that you were within the law.
Auto trader Promo Code
PostPosted: Wed Dec 07, 2011 1:55 am
i am moving up to marrietta in the summer/fall. my car is reg here in columbus under my moms name and address. since my care in now turbo, will i need to worry about emissions testing?
i still have factory cat on for now but will be swtiching to high-flow soon, plus i have a chambered muffler. will i need to worry?
ASAP
05 Spec-V/T :ninja:
